Voltage Gauge
Old Oct 22, 2006 | 10:23 PM
JonnysDodge's Avatar
Voltage Gauge
Hey you guys are great, have another question for you. When I start up my truck, or just idling at a stop light or just sitting there, the voltage meter goes down a little and then back up to normal. Just wondering if this could be my alternator? I could use some help here.
Have a 97 auto, #100 plate, 4" exhaust, and k&n intake, have egt gauge, and working on getting the kdp tabbed, and boost gauge.
Thanks
Old Oct 23, 2006 | 06:25 AM
Common's Avatar
Thanks
My guess is your grid heaters cycling...
but after driving a while, they should shut off...
Old Oct 23, 2006 | 07:59 AM
TxDiesel007's Avatar
100 percent in agreement here
Rick
Old Oct 23, 2006 | 08:13 AM
displacedtexan's Avatar
I guess I make three that agree.
Hey, I rymed!!!
Old Oct 23, 2006 | 09:12 AM
So if it does not shut off after awhile then what is the fix for that? And will it cause damage to the batteries or alternator?
Old Oct 24, 2006 | 10:14 AM
Could this be voltage regulator? I heard that this could be the problem. Any info on this?
Old Oct 24, 2006 | 03:27 PM
CTD NUT's Avatar
You better hope not.....the VR is an integral part of the PCM.
The grid heaters cycle on and off when the intake air temp drops below a certain temp....the cooler the climate you live in, the more frequently you will experience this.
Shovelhead posted a sticky that explains the grid heater cycling well.
https://www.dieseltruckresource.com/...d.php?t=120532
Old Oct 24, 2006 | 03:37 PM
4x4dually's Avatar
What year did they start using grid heaters? They weren't on the 12vers were they? The sig says '97 model. They didn't have 24 valves back then, did they? I think I'm having a brain fart. I'm blank. It has been a long day.
Old Oct 24, 2006 | 04:08 PM
CTD NUT's Avatar
Grid heaters have been there since the B series CTD was first dropped into a Dodge.
Old Oct 24, 2006 | 04:11 PM
4x4dually's Avatar
Thanks, I learn something everyday. I thought that was just a 24 valve thing. I'm still a pup here at DTR! I think that question just slipped me back a bit!
Old Oct 24, 2006 | 06:16 PM
Thanks for the info, however i read shovelheads post and mine happens at about 65-70 mph, he said that it should stop around 25. I had my alternator tested today and they say that it is not working right, so I should replace it. So I guess I will start there. Thanks for all the Help
imbodie
21
Jan 8, 2024 08:49 AM
06Cummins
15
Jan 21, 2019 10:24 PM
Tayloe08
Nov 18, 2005 03:26 PM
Rigg4x4
Nov 23, 2002 06:42 PM
