very strange p-pump operation....
Old Jun 1, 2011 | 02:34 PM
dodgetrucker75's Avatar
a while back i installed a raptor lift pump and set the pressure about 28 psi, the next day it was only showing about 21 psi.... after driving for a couple weeks and watching all of this, it goes back and forth at start up, sometimes its 21 sometimes its 28, when its showing 28 i have now noticed that the engine feels very sluggish, slow too spool, runs very high egt's and smokes like a freight train on light accelation, but when its showing 21, i can barly keep the tires stuck to the road, and it runs awsome????? anyone got any ideas as to what the heck this might be?
Old Jun 2, 2011 | 10:05 AM
infidel's Avatar
Your pressures are all within spec.
I would verify that they are correct with another fuel pressure gauge.
Old Jun 2, 2011 | 02:43 PM
the pressures are correct, verified with two different gauges and has a brand new autometer gauge right now, but its the engine operation i am worried about,
to try an explain a little better... the pressures i gave are a max pressure i will see untill another start up, for instance today i start the truck and it showes 28-30psi and will stay there all day and maby for a few more days and runs like crap, and tomarrow when i start it, it may show 21 psi all day and run awsome....
Old Jun 2, 2011 | 04:54 PM
Tate's Avatar
How do you have the injector return plumbed? I can't really see any common symptoms, being that I run 40 psi on both my trucks and no issues like you describe. I'd think the fuel pressure is a symptom as opposed to a cause to your troubles, but I can't think of what. Have you tried regulating the fuel pressure down to your 21 and see what changes?
Old Jun 3, 2011 | 01:19 PM
i have the injector return t-ed into the injection pump return to tank, i havent tried lowering the pressure but before with my fass pump at 15psi, i couldnt get over 3200 rpm's.... idk maby im just crazy lol maby i got a wastegate sticking or somethin?
truckbouy2
Mar 29, 2008 10:48 AM
allmountainbike
Sep 11, 2007 09:11 PM
qwest
Jul 28, 2007 05:12 PM
micstep
Mar 6, 2005 10:08 PM
Patrick Campbell
Aug 20, 2004 01:07 PM
