Is this a vacuum leak?
Old Apr 9, 2013 | 09:22 AM
pearl's Avatar
I just replaced my AC compressor/dryer and recharged system. here's what's happening: AC works fine, and as long as I'm running at close to 1000rpm the switch works to direct the air flow through the "chest" vents. However, when at idle, the "chest" vents quit working and the air blows out the floor and defrost vents. Soon as I raise the rpms a little, the air flow returns to the chest vents. Also, sometimes when idling in gear the rpms will drop very low, almost stalling, and the oil pressure guage drops to 0. I wonderf if this occasional low rpm idle is related to whatever's making the air flow change at low idle? Thanks.
Old Apr 9, 2013 | 12:56 PM
infidel's Avatar
Easy way to tell if you have a vacuum leak is to run the engine, shut it down for five minutes then disconnect any vacuum hose.
It should hiss, if it doesn't you have a leak and need to go hunting.
A leak free system will hold vacuum for hours if not days.
jimbo486
May 8, 2016 06:07 PM
ceyl
Sep 23, 2004 08:02 PM
TurboAZ
May 18, 2004 02:08 AM
yorkpaddy1
Jan 24, 2004 08:05 PM
amartinson
0
May 4, 2003 01:55 PM
