v10 to 12 valve swap
Old Apr 15, 2015 | 07:27 AM
canamracing's Avatar
Looking at a southern v10 1997 Ram 2500. Own 94 northern rusted 12valve. How much work to swap the motors and auto trans? Doug 7f
Old Apr 15, 2015 | 08:46 AM
patdaly's Avatar
Going to be tough unless you use all mechanical and wiring from your 94. 94-95 used the RH trans, 96 up the RE.
As far as the rest, straight bolt in, cabs, etc are the same, just a pain to move all the wiring.
Old Apr 17, 2015 | 04:47 AM
Ok, guys. the v10 is a 1995 not 96. Would this be easier? Doug 7f
Old Apr 17, 2015 | 08:25 AM
patdaly's Avatar
Yep, should be easier, wiring "should" be the same inside cab, but you would need to invest in a 1995 service manual to be sure.
35 bucks at Genos Garage, cheapest info you will ever find.
Old Apr 17, 2015 | 10:18 PM
Ronco95's Avatar
"95 should be less wiring.
"96 up will be OBDII.
jaconst
26
Apr 7, 2019 06:52 AM
pcgym
Cummins Conversions
Dec 17, 2009 07:15 AM
mad2smile
May 9, 2007 12:57 PM
johnny5.9
Feb 22, 2007 02:21 PM
dtpatt2
Jan 14, 2005 04:56 PM
