unknown electrical stuff
Old Apr 20, 2006 | 03:14 PM
arroyojim's Avatar
Question unknown electrical stuff
could anyone tell me what the electrical device is forward of and underneath the passenger side battery tray?
i also just noticed a very small button under the dash between the brake and hood release levers. anyone know if this is stock or aftermkt? i think it may have to do with my alarm, but not sure.
thanks!
Old Apr 20, 2006 | 03:19 PM
JKM's Avatar
JKM
The headlight , seriously , as far as i know , there is nothing down in there.
Old Apr 20, 2006 | 03:22 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
is it shaped like a triangle and very small, bolted to the inner fender flat on the bottom, if so it is one of your airbag deployment switchs. if not and it looks like a small brake booster with one electrical harness comming from it and two vacuum lines comming off it, it is your cruise control acuator.
Old Apr 20, 2006 | 08:57 PM
JKM's Avatar
JKM
the cruise is on the drivers side.
Old Apr 20, 2006 | 09:00 PM
arroyojim's Avatar
"shaped like a triangle and very small, bolted to the inner fender flat on the bottom"
that's what it is. i was curious cause battery acid has caused some corrosion around it. i have replaced the batteries and am working at cleaning out the rust and such. can i just unplug that thing and unbolt it or will my air bags deploy?
Old Apr 21, 2006 | 08:46 AM
brn2fsh's Avatar
The item you are describing may be the battery heater.
Old Apr 21, 2006 | 04:04 PM
arroyojim's Avatar
wasn't sure if i could put a pic in a post, so i put some pics of the whatever it is and also of the little red button under my dash in my gallery if anyone wants to take a look. i've skimmed through some wiring diagrams but can't seem to identify either
Old Apr 21, 2006 | 04:45 PM
Partsman's Avatar
The red button is an alarm deactivation button so if your key fob battery goes dead you can start the truck, I'm pretty sure. Its not factory.
Old Apr 21, 2006 | 06:10 PM
JKM's Avatar
JKM
This looks like an airbag sensor to me, you should be ok to unplug it , but don't smack it with a hammer
Old Apr 21, 2006 | 07:35 PM
infidel's Avatar
It is the air bag sensor. If you unplug it your airbag light will stay on all the time and your airbag won't work.
EClancy
Apr 29, 2008 07:16 PM
brendangsxr
Nov 21, 2006 04:40 PM
Hondo
Dec 21, 2004 06:37 AM
ViperSBT
May 21, 2004 07:41 PM
moneypit
Aug 20, 2003 08:49 PM
