two questions
Old Jan 26, 2007 | 07:26 PM
sixguns's Avatar
two questions
I am relativaly new the DTR, I've been doing a lot of research on mods and maintenance and have found loads of info you guys and gals are great and thanks. I am in the process of fixing a few minor things on my truck this weekend and have a couple of questions. First I was replacing the exhaust manifold gaskets today and would like to know if anyone had torque specs for the manifold? Second I noticed that I have what looks like a crack on one of my blades of my turbo. Is this something I should be worried about or just leave it? I realize it probably wouldn't be pretty if it did break off.
Old Jan 26, 2007 | 08:14 PM
TxDiesel007's Avatar
IIRC
torque specs for the manifold are 38 ft lbs, but im not 100 percent sure.... Far as the broken turbo blades go, ive never seen them, i have seen striations on them that look like cracks... but no actual cracks. If you can confirm that it is a real crack, then id worry, if it breaks at a high rate of spinning, then youd really damage something... ID check it carefully if I was you...
Rick
Old Jan 26, 2007 | 10:22 PM
TIMMY22's Avatar
exhaust manifold bolts are 32 ft lbs.
Old Jan 27, 2007 | 05:59 AM
sixguns's Avatar
Thanks for the info, I'll take a closer look today.
outside304
Jun 12, 2010 06:14 PM
Totallyrad
May 23, 2010 12:42 PM
dieselcarpenter
Nov 17, 2007 07:02 PM
crobtex
Oct 15, 2006 09:59 PM
Dieseldude4x4
Jan 4, 2003 03:07 PM
