Turbo
First I suggest you read this> http://dodgeram.org/tech/dsl/more_power/power_p7100.htm
Second ignore all the charts and use a #10 plate.
Welcome...
1. Gauges
2. #10 plate
3. 3k governor springs
4. Scotty II Air System
5. Exhaust
6. Timing
7. Turbo
If you have either a 5 speed or an automatic.. You will need to do some adjustments to the plate to save the transmission until you have the money to either add a South Bend Clutch to the 5 speed or internals to the auto.
You will be a very happy camper!
Rick
1. Gauges
2. #10 plate
5. Exhaust
6. Timing
7. Turbo
Rick
Thanks some of u guys know what ur talking about, but which way do i get the timing adjusted to advance/retard, and what it the point of adjusting the timing? and the starwheel is that on the back of the afc housing a (little screw)
Engine timing requires specail tools that cost more than having someone else do it. Since it's usually a one shot deal most folks are better off farming it out.
Timing instructions here> http://dodgeram.info/tsb/1994/18-10-94a.htm
the star wheel is under the 8mm allen plug on top of the afc housing...check out this site it has all the parts and step by step instructions with pictures...
www.tstproducts.com
www.tstproducts.com
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
