Truck starts in second every odd once in awhile?
Hi All,
My truck seems to start out in second gear, maybe once every week or so, If I select 1st off I go, sometimes you just add a little throttle and it seems to kick in.
I think I have seen it before on the forum but could not find it with a search?
Truck is still runnin great though
very happy
very happy
If you've had ANY lockup shudder in the past you are getting friction material particles abraded into your transmission fluid. Changing the fluid helped, but you still have the particles (like sludge) in the valve orifices which ruins the 2-1 downshift. My truck did the same, the engine was overpowering the lockup and getting worse, more sludge. I had ATS replace the governor solenoid, governor transducer, and fluid, but the downshift problem returned. Thus an ATS transmission was in order. This transmission doesn't slip, no shudder, no sludge.
97catintenn
Jan 7, 2010 11:33 PM
rjm022
Sep 9, 2008 02:38 PM
arroyojim
Sep 15, 2006 02:19 PM
