truck just ate a belt!
Old Apr 16, 2004 | 06:04 PM
Jambbii's Avatar
Unhappy truck just ate a belt!
Luckily I have life time napa stuff but why would my truck destroy a belt like this, it was only 6 months old with not many miles on it. I think when it happend I got on it a little bit but not for long and then I noticed my a/c was getting warm. When I got home I checked it and my truck ate the belt for lunch.
Thanks
Old Apr 16, 2004 | 06:08 PM
linetrash75's Avatar
if it ate one side of the belt you might check your tensioner . if the bearings bad it will walk the belt of to one side of the pulley also my bearing was good but the pulley itself was wore more on yhe inside also walking the blet off.
jed
Old Apr 16, 2004 | 07:59 PM
infidel's Avatar
Many times the pivot point of the tensioner wears out and causes the pulley to tilt. There should be very little front to back play on the tensioner arm.
You have to replace the entire unit if there is.
Old Apr 16, 2004 | 09:13 PM
INJECTOR JACK's Avatar
Unhappy Belt problems
I would take a good look at the belt tensioner as others have metioned.
The bearing in the idler may be bad or the spring broke in the tensioner. Cummins engines don't have many problems with belts unlike those Power Joke engines.
Old Apr 16, 2004 | 09:26 PM
Cummins66's Avatar
Just to echo everyone above check the belt tensioner. Had the same thing happen on our 91, it was riding off the roller. New tensioner and new belt, no more problems.
Old Apr 16, 2004 | 11:25 PM
Scubasteve's Avatar
Yip, i have seen where the plastic on the tensioner was missing and the belt was running on the housing the bearings sits in on the tensioner pulley!!
Belt has to make a super tight bend and doesnt get the tension it needs either.
New belt and new tensioner and you should be good to go either way..
Good Luck
Jason
Old Apr 16, 2004 | 11:51 PM
Jambbii's Avatar
How much do these tensioners run?
Old Apr 17, 2004 | 12:41 PM
Partsman's Avatar
Could also be your AC compressor just bit the big one, thats what happened to me.
Old Apr 21, 2004 | 10:13 AM
earl78621's Avatar
something happen to me. ended up being a wobbly water pump pulley
DodgeDiesel61
0
Jul 28, 2010 11:14 AM
PaulDaisy
14
Jul 13, 2007 07:13 PM
mhuppertz
Sep 23, 2005 04:53 PM
Bobcat698
Jul 29, 2005 02:45 AM
