fuel shut off silenoid
Old Apr 21, 2004 | 02:56 PM
AZGEARPRO's Avatar
Question fuel shut off silenoid
For the past few weeks, every so often the truck cranks but wont start. I have to get out and move the fuel shut off silenoid up and down and it will start. well it is doing it everytime now and I have noticed that my throttle will not travel to the full position now. I did notice that the boot underneath is gone so I am thinking a good cleaning may help it any ideas?
Old Apr 21, 2004 | 03:19 PM
AZGEARPRO's Avatar
thanks john, youve been a big help
Old Apr 21, 2004 | 04:34 PM
infidel's Avatar
NO, NO, NO!!!
Don't replace the solenoid, it's the most needlessly replaced item on a 12 valve engine and expendsive to boot. Usually they are replaced by folks who are just throwing parts at a problem. The solenoid is a simple heavy duty unit that rarely fails. About the only time one fails is if the starter sticks on charging the lift up coil which overheats the solenoid. You'll know it if it ever happens, smells like something burning.
Sometimes the boot will fall apart allowing crud to build up, cleaning is all it takes. I make my own replacement boots out of a short section of bicycle inner tube and a couple of cable ties, lasts longer than the $30 ones Cummins sells and works just as well.
Most often the problem is the solenoid relay or the just the blue wire from the battery is corroded. Get a new relay from www.fostertruck.com or a new blue wire (fusible link) from the auto parts.
Old Apr 21, 2004 | 04:41 PM
AZGEARPRO's Avatar
WOW! I will try that, the silenoid looks pretty easy to take off and on, thanks a ton for all the info guys.
Old Apr 22, 2004 | 12:23 PM
Palmetto_kid's Avatar
Try replacing the relay first!!
I lived with the same problem you have for almost a year!!!! Until one day I bought the relay from fostertruck.com. Cured the problem in about 1 minute.
Do the relay man!!
Smokkin
Apr 4, 2012 02:43 PM
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
Dean Snow
Sep 26, 2007 03:40 PM
doomgaze
Dec 12, 2002 05:18 PM
