truck jerking
Old Feb 23, 2009 | 04:27 PM
Kiff's Avatar
truck jerking
I have been having a strange issue ever since buying my truck in december. It feels like the truck jerks when I get on or off the throttle quickly. I really have to feather the throttle to have a smooth drive. At first it seemed like a motor mount, same symptoms I had with my toyota, but I checked under the hood and didn't see any excessive movement from the motor while revving it. I'm wondering what to check next? Too much lash in the diff? worn gears in the trans?
Old Feb 23, 2009 | 07:12 PM
JohnX's Avatar
Check u-joints while your at it. Have someone help so you can look at the joints while they load it up a little in gear. Try going from drive to reverse and back while keeping the rpm a little over idle.
Old Feb 23, 2009 | 07:44 PM
Kiff's Avatar
the truck's a 5spd if that help?
Old Feb 23, 2009 | 10:36 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
What year of truck??Is it the drive train jerking or is it the engine surging?
Old Feb 24, 2009 | 12:18 AM
Kiff's Avatar
Truck is a 97, feels more like drive train jerking, as there is a slight delay after the engine RPM drops or raises
Old Feb 24, 2009 | 10:33 AM
infidel's Avatar
Most common cause of jerking from a sensitive throttle is a broken or unhooked throttle return spring(s).
There are two springs, one inside the other that stretch inbetween the linkage and power steering pump.
You can replace with hardware or autoparts store springs for less than five bucks.
Also read this http://dodgeram.info/tsb/1997/18-29-97.htm
The kit in this TSB is over $100 and is basically just stronger springs with a bunch of other parts you don't really need.
Also check that the two small bolts on the rear lever in fig 1 in the above link are tight.
Old Feb 24, 2009 | 11:09 AM
Kiff's Avatar
It's not really a issue at steady or mild acceleration. That's really the only way I can keep the truck steady. Would the return spring affect both acceleration and deceleration?
Old Feb 24, 2009 | 12:42 PM
infidel's Avatar
Without strong return springs it's very hard to keep your foot steady on the pedal at any time with truck and road vibration fighting you.
Old Feb 24, 2009 | 04:59 PM
Dartmouth 12V's Avatar
If you get it both coming onto and off of the throttle, there is a good chance that it is from all the slack in your driveline. You can lie under the truck with it in gear and try to rotate the driveshaft and then do it again out of gear. If there isn't a lot of slack there, it is likely to be your throttle return spring.
Old Feb 24, 2009 | 08:16 PM
Mikestowing's Avatar
Yes, If not return spring most deff. slack in the drive train. I had the this problem with a 97 3500 w/ 270K miles. Between the sloppy rear end and the sloppy 5 speed tranny you would almost have delay in the throttle responce LOL..... It bucked and jurked every time i touched the go pedal. I couldnt stand it i sold that pos.
Old Feb 25, 2009 | 03:10 PM
Dave Miller's Avatar
My 97 3500 5 spd 4x4 bucked like crazy before I put the missing throttle spring back in. It had a piece of missing spring still hanging on the linkage. I got 2 new springs at dealer for $10 I think and it fixed my touchy throttle.
Mine had 2 springs parallel 2 each other with grey plasitic ends that popped onto the ball studs (under the fuel solenoid in that area). I had to use a mirror to see it since its hard to see under that area. I found one grey plastic end hanging on a ball stud joint and spring was missing. Throttle was very touchy and bucked alot. Throttle was too sensitive without all the springs.
Old Feb 25, 2009 | 09:17 PM
Kiff's Avatar
in gear, I have no slop. Out of gear, I am getting maybe 1/2" of turn, I would say some slop. Guess I'm looking for the slop after the trans? I dont see any signs of worn u-joints, so work diff gears? am I able to re-set the lash of these things? it's got a dana 80.
Old Feb 25, 2009 | 09:33 PM
1/2" of turn isn't actually all that bad with these trucks but it isn't good.
I would strongly discourage resetting the lash. Your gears are worn into how it is set and if you reset it, it will probably howl for longer than you can stand. I have a fair amount of slop in mine and have just learned how to drive with it. I had completely forgotten that I had that problem until this thread.
Old Feb 25, 2009 | 09:53 PM
BigIron70's Avatar
Cummins Guru
There is a recall for throttle linkage and it comes with new springs. Recall B-15
IanM
Jan 29, 2011 02:52 PM
Jeff5886
Jun 27, 2009 07:22 PM
Big Jimbo
Sep 1, 2005 08:27 AM
NO1B4ME
Jun 29, 2005 06:53 PM
gsim1228
May 23, 2004 09:15 PM
