trany shift question
Old Nov 25, 2011 | 12:51 AM
oldblues's Avatar
Question trany shift question
hi
a friends 97 stock trany will shift 1 to 2 fine but does not shift to 3 rd without moving shift lever to N then back to drive then it shifts into 3 rd ?
no slipping when in gear !
just replaced the solinoid pack and gov pres sensor !
recent new tps .
none of these items seem to help ?
any ideas ??
thank you !
Old Nov 25, 2011 | 01:08 AM
green95's Avatar
Aren't the solenoids for OD and TQ lockup?, I hope you guys did the general fluid/filter change and band adj. I don't have my service manual inside, I'l get it in a few hours and check the troubleshooting for 2'nd to 3'rd shift and post it up for you.
Old Nov 26, 2011 | 06:19 PM
oldblues's Avatar
yes new fluid ,filter and no codes ?
Old Nov 27, 2011 | 09:36 AM
j-fox's Avatar
Pressure testing with gauges will help, but I'm guessing the front cluch seals are leaking, delaying the shift. Very common in those years.
Old Nov 27, 2011 | 11:41 AM
cj360trider's Avatar
green95 jus a side note. don't forget ur 95 has a 47RH and the 97 has a 47RE they're the same but different LOLOL
Old Nov 27, 2011 | 06:19 PM
green95's Avatar
I cant find my manual,I'm still looking,Man gettin senile already lol
Old Nov 28, 2011 | 07:31 PM
green95's Avatar
All indications are the Gov.assembly or clogged filter,But you changed those. Book suggests looking at your linkage for binding or Adj.issues.... sometimes it's the simple stuff
winkdemon
Sep 22, 2008 09:18 PM
A_Manke
Feb 12, 2008 11:08 PM
Greguw
Nov 20, 2005 10:18 PM
bigfoot
Oct 8, 2002 04:17 PM
