very bouncy
Old Nov 25, 2011 | 12:09 PM
DC199512V87's Avatar
Red face very bouncy
so we recently got a foot of snow up here and i got my brand new winter tires on- lotsa traction. but anytime the tires do spin the axle(s) start bouncing uncontrolably. this will happen in 2 or 4wd. its to the point of thinking something will break. unless i wind it right out and the tires are just screaming any spinage causes this bounce. is this normal and should i b looking at trac bars or is something loose/broken?
Old Nov 25, 2011 | 03:47 PM
BILTIT's Avatar
Try replacing the shocks.
Old Nov 25, 2011 | 07:04 PM
ok. its not like a soft ride bouncy. more like hammers hard and fast up and down.....
Old Nov 25, 2011 | 07:39 PM
Tate's Avatar
Mines the same way. I've just learned to live with it, but I'd love to get rid of it without replacing parts needlessly.
Old Nov 25, 2011 | 08:16 PM
but aren't traction bars supposed to eliminate that issue? that's the whole point of them no? to stop flexing? im sure all the sled pullers don't have this issue
Old Nov 25, 2011 | 10:09 PM
BILTIT's Avatar
Traction bars will help but it shouldnt be that bad to begin with unless your shocks are wore out or springs are soft.
Old Nov 26, 2011 | 12:00 AM
98fargo's Avatar
Mine is also the same, hasn't ever changed, from stock height to lifted, new shocks or old shocks. it's wheel hop, traction bars will help.
Old Nov 27, 2011 | 06:17 PM
green95's Avatar
did you do a suspention lift to install the 35's,if you changed the leafs or changed the arc via add-a-leaf,did you change the angle of the driveshaft?if the pinion angle is too nose down you will get bad axel tramp as the springs will want to wind up beyond norm during accel.
Old Nov 27, 2011 | 09:00 PM
no lift mods whatsoever anywhere, just threw 35s on the stock rims. problem is theres snow on the ground up here for half a year and spinning tires is gonna happen, even if its accidently. cant c that not doing damage to something so looks like some trac bars are in order. right after the lift.....
Old Nov 27, 2011 | 10:52 PM
SIXSLUG's Avatar
Put some weight in the bed.
Old Nov 28, 2011 | 07:53 PM
green95's Avatar
Yeah,I had the same trouble with an old 5spd.yj with 33's. My experiance is that once that (what is referred to as srping wrap) starts it rapidly ruins springs,Check for broken leaves,If this just started it's possible that you have a cracked leaf,those springs are prettly HD. so it's suprising to hear that this is happening to you and others since nothing was messed with,I ended up buying a single ladder bar set-up that had brackets I had to weld to the tube on the drivers side about 2" inboard from the spring perch and then I had to fab a crossmember for the foward attachment point, the unit was triangulated,upper and lower mounting at the rear and a single point at the front,sort of a shackle type mount with the shackle going up and the bushing at the top,a non moving set-up with a poly bushing in front and Heim joints at the rear with the lower rear link adjustable for some preload,This worked So great and did not limit travel or harm ride quality. Look around online there are many manuf. I even think there is a similar kit maketed by Rancho.
Tommy93w350
14
Jan 17, 2008 08:51 PM
Rushford
23
Aug 26, 2007 07:21 PM
Tommy93w350
15
Jul 26, 2007 12:02 PM
MikeThomas
May 21, 2007 09:30 AM
Luckycharm1
28
Sep 9, 2005 09:52 AM
