Transmission Shift Pattern
??? Can somebody tell me what the shift order is on a 47re transmission.<br>I think it goes as follows: 1,2,3,tc,od.<br>If im wrong please correct me.<br>Thanks<br>Allen
Re:Transmission Shift Pattern
cummingetsome is right, I put a indecator light under my dash that is wired in to my tc lockup switch and it does not come on until tc locks up. when i lock it up manually, it comes right on, when i have the switch off and let the tc lock up by itself, it goes from over drive then to lock up, haveing the light, i always know when im locked in.. pretty simple to hook up too!! ;D
Doodah, can you manually lock up in 3rd with OD off? I'd like to be able to keep 3rd locked while on the Dyno. Which wire are you picking up from the tranny to keep it locked up? Thanks, Lon
chop342
Aug 18, 2005 11:47 AM
rich
22
Mar 30, 2005 04:37 PM
schu
15
May 26, 2004 01:56 PM
