Transmission servo?
If it's only blowing while in motion I would look into the governer pressure sender/solenoid wiring. I'm not even sure off the top of my head what the #9 fuse is, is it transmission? Does it blow the fuse as soon as it starts moving or does it take a while? I would do some searching on the pinout on the connector to the trans, and start tracing things back from there to find out where the short is. Sorry I can't be more help, good luck.
There were wires next to the front shock stud that were grounding..DUH....sometimes I get too deep and forget the answer is usually something simple.
All is good with the Dodge now...I like her a lot more when she isn't fussin...
robert chilton
Aug 27, 2005 01:33 PM
FireNhole
Mar 14, 2003 04:56 PM
BoldtsWagon
Jan 24, 2003 11:05 PM
