transmission prolblems
Old Aug 9, 2008 | 04:33 PM
still smokin's Avatar
i got a 97 automatic that has 180 thousand on it. heres the problem ive got when i put the truck in gear with the brake pedal applied down like i was going to stop it will bog down and eventually die.does this sound like trans or what
Old Aug 9, 2008 | 11:24 PM
badme's Avatar
Sounds like the lock up converter is not unlocking. I would say stuck solenoid.
Old Aug 10, 2008 | 09:25 AM
impmouse's Avatar
whats the idle at wiyh the truck in park?... can to two foot the brake and gass to keep it running with it in gear?
Old Aug 11, 2008 | 07:37 AM
bmoeller's Avatar
Either that, or the idle is to low.
Old Aug 11, 2008 | 06:51 PM
when brake applied and gas down to floor it will still die.if soliniod is stuck what can i do.
Old Aug 11, 2008 | 06:52 PM
oh with truck in park it idles at 1000 to 1100
Old Aug 11, 2008 | 08:05 PM
badme's Avatar
Put in a new one.
Old Aug 11, 2008 | 08:09 PM
badme's Avatar
Originally Posted by badme
Put in a new one.
While you are there you should make sure all the valves move in the valve body.
A stuck valve could be trouble too.
Old Aug 12, 2008 | 05:35 PM
tried all gears today still does same thing. i got under the truck 2day to find out the trans. isnt even bolted down so i know some 1 has been in there.
Old Aug 13, 2008 | 09:36 AM
Coagulation's Avatar
Muted User
What do you mean it isnt even bolted down??
Its not bolted to the crossmember???
Old Aug 13, 2008 | 05:35 PM
no it wasn't even bolted to the crossmember
Old Aug 14, 2008 | 07:35 AM
Muted User
LMAO wow some skilled mechanic must have been working on that.
So the engine was the only thing holding the trans in place??
Old Aug 14, 2008 | 10:10 PM
jonnyjpr's Avatar
My work truck is a 97 also. It does the same exact thing. Havent done that when i first got it. Thought it was the fuel filter at first but nope. And i dont think its idleing too low either.
Old Aug 16, 2008 | 09:01 AM
DodgeFreak's Avatar
Some times the screen infront of the solinod gets plugged up. So all you have to do is pull the pack down pull the gasket off and replace with a new one.
Old Aug 17, 2008 | 08:45 PM
today i bolted it down to c if acted any different. i drove it about 2 miles and it would goall the way tell ovd. the rpms just went to 3000 and it wouldnt shift into ovd. but the rpms at idle are at 800 to900 now so i thank that is what it should be at right or wrong.
Dauntless
15
Aug 30, 2016 08:37 PM
dsl-nut
Mar 22, 2003 12:12 PM
quantrill88
Mar 19, 2003 05:04 PM
harleydog
Mar 13, 2003 07:34 PM
jonesr2
Oct 12, 2002 04:49 PM
