Transmission fluid leak
Old Apr 1, 2012 | 11:03 AM
coon-dog7070's Avatar
Got a leak that I can't fix. I replaced teheran metal transmission lines going to the trans case about a year ago, but lately I've noticed a leak near the quick disconnects at the lines that go from the trans cooler to the metal trans case lines. I disconnected the lines at the quick connects and inspected the o-rings, they looked ok but I replaced the lines anyway. I replaced the lines started the truck, applied the parking brake and put the truck in drive, saw no noticeable leak. Thought the problem was fixed. Then this morning i went to do some errands and came back home and noticed that i still had a leak .So the metal trans lines are somewhat new and the trans cooler lines are brand new. I didnt replace the little keepers at the disconnects but I didn't think that would be a issue. What is going on!?!?!?
Old Apr 1, 2012 | 01:00 PM
BigIron70's Avatar
Cummins Guru
Check around the line where the crimp is also check line for cracks at the flare, just where it goes into quick disconnect. Mine had a small crack there and was hard to find it.
Old Apr 1, 2012 | 03:59 PM
im thinking about just packing the quick connect especially around the seal with rtv silicone, im hoping to stop the leak for a while (about to sell it). I will check around the flared end of the hard metal lines again but when i installed the new lines i could not see anything out of the ordinary.
alan96
Sep 8, 2011 10:11 AM
jaredb900rr
Oct 1, 2009 11:05 PM
Tommy93w350
Jun 26, 2007 04:42 PM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
