Transmission Cooler Lines Leaking
Plastic inserts for transmission cooler lines are leaking. I was told that you could cut the ends off the rubber lines coming from the cooler and install new ends. Does anyone have the part number to these new ends or part numbers to anouther solution. Thanks in advance for your help!!
91rangerturbo
May 8, 2008 08:05 AM
91rangerturbo
Mar 6, 2008 09:40 PM
