Transfer Case problems NP241?
Old Mar 16, 2003 | 08:02 AM
hw101's Avatar
95, 3500 5 speed, I get a clunking noise that sounds like a u-joint failing. This can be with or without load, and is not predictable. I've checked the u joints and don't think the sound is coming from them. Is it possible the chain is slipping? What should I look for?<br><br>Thanks,<br><br>Bill ???
Old Mar 16, 2003 | 09:02 AM
bulthisl's Avatar
Re:Transfer Case problems NP241?
Check the 4 bolts in the yoke that holds front driveshaft to T-case. They can come loose.<br><br> : Eddie : 8)
Old Mar 16, 2003 | 11:50 AM
hw101's Avatar
The Bolts are tight, the carrier bearing seems sloppy, could that cause the noise? I raised the truck and tried forward and reverse, reverse seems to clunk the most.<br><br>Thanks,<br><br>Bill
Old Mar 16, 2003 | 12:07 PM
bulthisl's Avatar
Yes the carrier bearing could be thwe prob as well.<br><br> : Eddie : 8)
65fury
Nov 26, 2009 07:50 PM
ve7kilohertz
Dec 28, 2008 07:19 PM
rschaer
Aug 6, 2007 09:02 PM
tacoma
Jun 7, 2006 12:50 AM
