Tranny trouble
Tranny trouble
Third gear went gone a few days ago in my 89 W250. I had accelerated quickly in 3rd of course, to get around a bozo and as I came to the next stop light, my engine seemed to stop firing in one of my cylinders. Within 30 seconds it was smooth again. I went and parked for an errand and when I proceeded to drive again, 3rd gear was gone. Just air, no engagement when the clutch is released.
The engine deal is probably separate, as I've been working out some water in fuel problems since a bunch of snow melted into my tank after loosing the fuel cap...oops. Bleeding air from the injectors has become second nature.
The tranny has been sticky inbetween 4th and 5th and would often jam in 5th or in that region of stick use.
I had already been planning a front seal replacement on the transfer case as well as tranny mounts. I am pretty sure my main seal is leaking pretty bad, as I loose oil pressure at normal operating temp and there is an obvious drip and smoke from that area once up to temp.
I got a quote for a reman tranny + stock clutch and misc replacement parts + main seal and labor for $2300.
I read a post recently where someone lost a roll pin in a shifting fork, which could be a culprit. Its either do it all or mess with the tranny from the top (cut a hatch for access in floor)and live with a leaky main seal. Thats not ideal to me.
I bought the truck out in Washington in October 2012.
The truck has either 127K or 227K. Its only got the 99999 odo.
I am a busy welder guy and dont have a good place to do this work myself overtime.
Any thoughts or advise on what to do anyone?
Thanks
Thanks
ridlangus123
Dec 30, 2013 08:36 PM
Black Dog
Dec 3, 2009 08:18 PM
