Tranny Hanging
Old Feb 28, 2007 | 12:02 PM
xxsniperx's Avatar
Tranny Hanging
My tranny just started to hang for a split second inbetween 1st and 2nd shift. Not all the time and it seems like only when i use real light throttle. Any ideas? I checked fluid level its good. I have a new billet torque converter and a BD valve body.
Old Feb 28, 2007 | 02:47 PM
mainer's Avatar
my 98's tranny shifts funky from 1-2 when taking off easy.... not sure what it is kind of hangs like its slipping, but if i shift it manually it shifts nice and crisp/ firm.....
Old Feb 28, 2007 | 08:47 PM
ckt_santiago's Avatar
The kick down band has come out of adjustment/worn a little. It is recommended maintenance to adjust the bands with every tranny fluid change at 15k intervals. Your average everyday Haynes Manual will tell you everything you need to know on how to adjust the bands. Just to let you know though, a torque wrench that measured in INCH pounds is required...
Oh and if the Haynes Manual doesn't say anything about it the torx head screws that hold the filter on are supposed to be put down to 35in/lbs and that has to be exact as those three screws are part of the what holds the valve body together. It is all machine fit and triple stacked, so any warp to the valve body and your transmission will not shift right...
Old Feb 28, 2007 | 11:10 PM
xxsniperx's Avatar
Thanks i'll adjust soon. I did the adjustment on the side of the tranny anyone have info on the one inside the pan?
jriggs_18
Aug 25, 2006 12:20 AM
satburn
Competition / Pulls / OffRoad
Jul 28, 2006 06:13 PM
04 SO CA
Apr 23, 2006 01:33 PM
Cowboy_Customs
Apr 19, 2006 12:15 PM
