Tranny cooler lines.
Old Oct 27, 2023 | 08:10 PM
Timmytorco's Avatar
No, I don’t want a Bud Lite. Anyone know what kind of fittings are in the trans and the air to air for the cooler lines on a 93? Lines seem to be NLA, and I can’t repair mine. They’re rusted and leaking catastrophically. I’m just going to make new ones with hydraulic hose at work.
Old Oct 31, 2023 | 10:47 AM
texasprd's Avatar
Check RockAuto - it looks like they currently have one cooler line from two suppliers. I'm not up on the lines for the 1st gen trucks or the differences between W and D models, so you need to see what they have. If you have a 47RH, the threads in the case ports are probably 1/4" NPT - that's what they are on my 47RE, and the 47RH is very similar in a lot of respects (assuming you have the 47RH).
Old Oct 31, 2023 | 06:07 PM
Timmytorco's Avatar
not the ones I need. I looked at those. They go to coolant cooler to trans. I need trans to air to air. I’m going to just make hydraulic lines to replace them. Can’t even TIG they’re so rusty.
Old Nov 2, 2023 | 09:55 AM
texasprd's Avatar
Hydraulic hoses seem to be a fairly popular replacement for the metal lines. About a year ago, one of my metal lines rubbed through (2nd time this has happened). I got replacement metal lines and converted from quick-connect fittings to flare. Even after a lot of effort getting some of the flare fittings to start, one flare connection still leaks ever so slightly. I got a kit of "push lock" ("field attachable") hoses from a "reputable vendor" and will be installing that when I can make time (I've already done some of the hose/fittings assembly). I'll probably add some anti-abrasion cover on the hoses.
Old Nov 2, 2023 | 12:37 PM
Timmytorco's Avatar
I’ll use JIC ends and NPT ti JIC nipples likely. JIC seal well and are low torque
bway1341
Sep 20, 2011 05:44 PM
454 no more
Jan 22, 2011 01:08 PM
91.5 beater
Jul 20, 2008 01:00 PM
jims-1993
Nov 5, 2007 10:36 AM
mkrenn
Apr 3, 2005 08:28 AM
