tranfer/lift pump question
Old Dec 20, 2005 | 12:59 PM
TIMMY22's Avatar
i just replaced my fuel module and fuel lines from the tank to the engine.
after priming with the manual bulb, i started the engine. after the engine started, i could smell an electrical burning smell. i turned it off and went to look under the hood to find the top plug on the tranfer pump hot and smoldering.
i don't know what this plug does? some kind of heater? after it cooled, i pulled the plug out of the socket on the tranfer pump to find the end all melted together.
there is a top plug and a bottom plug. this happened to the top plug.
i seperated the wires and taped them up. i then stated it up again and it ran fine.
i have 2 questions...
1. does this set of wires have anything to do with the wiring on the module?
I ask this because it happened instantly after changing the module. perhaps i bumped then with my arm installing the new fuel lines?
2. what do these wires do? do i need them? i'm in a cold climate, but not to often does it go below zero.
Old Dec 20, 2005 | 04:28 PM
TIMMY22's Avatar
ok, its to the front of the lift pump. it's the fuel heater.
buy some research i did, i believe the top plug is the t-stat and the bottom is the element. (line voltage setup)
im finding a part #'s of 3843722s and 3907766s
which one is the t-stat?
are these fleetgard #'s or cummins #'s or both?
Old Dec 20, 2005 | 04:32 PM
TIMMY22's Avatar
are those torx screws that hold it in?
boy, that is in a tough to reach area!
Old Jul 29, 2006 | 03:21 AM
Katmandu's Avatar
Question
I just found my plug all melted up too.
How did you wire it back together ??
Dirt_Diver
Jan 7, 2011 10:35 AM
Mopar Mike
Apr 27, 2010 02:28 PM
tsak01a
14
Jul 7, 2009 05:27 PM
DNRCustoms
Jan 21, 2009 07:22 AM
ram2000tuf
Aug 8, 2004 06:51 PM
