TPS question
Old Dec 1, 2004 | 10:51 PM
alaskanassassin's Avatar
TPS question
Can anyone tell me if this is a TPS problem. While accelerating up a steep hill I press the throttle and rpm's barely move, now if I give it a quick pump of the throttle the rpm's jump about 500 and accelerate pretty good. Even on flat terrain I have tried it, and it seems to act the same. Thanks
Old Dec 2, 2004 | 09:59 AM
kandgo's Avatar
Sounds like your tps is working properly, when you let off the throttle the torque convertor is unlocking as it should be. When you are going on a flat road try bumping your brake and it will do the same thing if working properly. Do a search on TPS adjustments as they do need readjusting from time to time. Goodluck,,Rick
whosdunit
May 17, 2014 08:54 AM
Cummnzpowr
Jul 13, 2004 01:44 PM
Mike S.
Jan 24, 2004 05:19 PM
Farmall
Feb 8, 2003 01:02 AM
