Towing in overdrive
Old Jul 1, 2009 | 10:40 AM
RPegram's Avatar
Towing in overdrive
I just purchased the '96 listed in my signature. I bought this truck (174000 miles)with the intentions of pulling a 6,000 lb travel trailer on vacations. It is stock except for the exhaust. I am not planning on any mods to increase HP. I want to know is it safe to tow in overdrive while at interstate speeds (55-65)? I am going to add some gauges, but have not had a chance yet (I was more worried about KDP and brakes). My main concern is the torque converter and overdrive planetary. I have talked with my local trans guru and he will help me modify the valve body to increase pressure. He does not advise OD while towing, but I wanted input from those with experience. Any advise and experience any of you have with doing this with this model (stock) trans would be greatly appreciated.
Old Jul 1, 2009 | 11:43 AM
~Angry Tractor~'s Avatar
I start out with OD off and once I get up to about 50 mph I kick on the OD when towing. If I'm towing in town I leave it off. No problems here.
Old Jul 1, 2009 | 06:42 PM
infidel's Avatar
As long as it's not hunting in and out of OD no problem towing.
Old Jul 1, 2009 | 09:52 PM
Pete Miller's Avatar
Install a transmission temperature guage. If it's cool, you're cool. I tow a 7000# boat behind my '96 CTD with a 2500# camper in the bed in Arizona and it doesn't get hot anymore since I added a Mag Hy-Tec double deep trans pan.
Old Jul 2, 2009 | 01:30 AM
cumminsdriver635's Avatar
You will be fine towing in overdrive at highway speeds with stock power. Especially if you modify the valve body for more pressure.
Eric
Old Jul 5, 2009 | 07:53 AM
cheapskate's Avatar
i tow around 12,000 or better quite a bit, and when i'm going to be over 50 or 55 its always in overdrive. truck has 220000 miles, with a stock trans.
Old Jul 5, 2009 | 08:12 AM
torqmonster's Avatar
I have a 98 12v auto, I don't have a OD on/off switch?
Old Jul 5, 2009 | 11:36 AM
infidel's Avatar
Isn't there a button on the end of your shifter?
Old Jul 5, 2009 | 11:58 AM
cmac's Avatar
my 96 5-speed has a od on/off switch where the fog light switch is..... not sure why its there....
Old Jul 5, 2009 | 06:06 PM
infidel's Avatar
The OD switch was on the dash next to the radio until '98 when it was moved to the end of the shifter.
Don't know why your 5 speed has one except it's no wonder Chrysler is bankrupt.
Old Jul 5, 2009 | 06:34 PM
jcarrillo's Avatar
I tow 14k#'s everyday for work and my engine gets hot if I don't put it in overdrive or else drive slow. I don't see a problem with pulling in OD. I'll second on the trans temp guage. If you dont know what your tranny temp is, you don't know your destroying it. When the temp is high you can simply back off and save yourself headaches.
Old Jul 8, 2009 | 09:50 AM
No, but that would explain it. When I bought the truck whoever had it before me put some goofy aftermarket big ugly **** on it, apparantly they didn't think it was important to have that button. I'll have to look into that. It's been towing good in OD so far, it's getting a 5 spd soon anyway!
RTCRam
Oct 4, 2012 01:43 PM
72demon440
Apr 27, 2007 10:45 PM
jgn
Jan 11, 2005 06:47 PM
Jones0027
Jan 15, 2003 02:38 PM
