Torque converter stays locked up
Old Mar 12, 2006 | 09:37 AM
bigrigger's Avatar
Unhappy Torque converter stays locked up
My torque converter occasionally stays locked up when i come to a stop and will not unlock unless i shift to neutral and back to drive I would like to fix this problem but don't really know where to look ,don't want to wreck my new tranny .truck is a 98 quad cab auto 47re 4x4 .
Old Mar 12, 2006 | 09:42 AM
marine4life's Avatar
can you force it out of lockup with the overdrive button. what about dropping from drive into 2, 1, what hapens, still locked up
Old Mar 12, 2006 | 10:23 AM
bigrigger's Avatar
Thanx for the quick reply i'll try those suggestions next time it happens
Old Mar 12, 2006 | 12:14 PM
Rrloren's Avatar
Had the same problem a while ago and it was the Trans speed senser. Cheap fix.
Old Mar 12, 2006 | 05:00 PM
bigrigger's Avatar
thanks for the quick reply any idea how to tell if thats the problem
Old Mar 12, 2006 | 05:34 PM
Brock's Avatar
what is happening to let you know it is locked up when idling and stuff....?
Old Mar 12, 2006 | 05:51 PM
bigrigger's Avatar
When i try to take off from a stop the engine just lugs like it is in to high of gear or the brakes are stuck on
Old Mar 12, 2006 | 07:39 PM
infidel's Avatar
If the TC was truely locked the engine would stall when you come to a stop.
I think you have something else going on.
Old Mar 12, 2006 | 07:50 PM
true, very true. maybe it doesn't shift down out of third gear. i know i can still take off very well in second so this might be what is happening. just a thought. possibly a valve body problem?
Old Mar 13, 2006 | 08:30 AM
Rrloren's Avatar
Mine stalled when coming to a stop cause it was in lockup. After an hour or so it performed perfectly , but I got it fixed. The truck shifts better , it had been holding 1st. gear till over 2000 rpms for a while, now the shifts are great.
Old Mar 13, 2006 | 05:36 PM
Ramdriver15's Avatar
if its your brakes when you went to take off, you willl feel a clunck, that is happening to mine... its the rubber hoses to the caliper... im replaciung the other one tomorrow.. hope itll be fixed
Old Mar 18, 2006 | 07:49 PM
bigrigger's Avatar
Unhappy
It happened again today while in town and when i turned the o/d off it seemed to be alright. Does this still sound like the vss ,also my cruise control has been acting wierd if i set it at 95 km/h it will go up to 110-115 if i don't catch it
Old May 19, 2006 | 05:24 PM
Viesel's Avatar
Did you ever get this fixed? Mine started to do the same today and was wondering what part I need to fix it and where it would be located.
Thanks
fortunate1
Jun 11, 2013 08:54 PM
'strokeThis_'07
Jan 18, 2013 07:03 PM
Otis
27
Feb 17, 2012 05:18 PM
chromegrill
20
Apr 5, 2007 12:56 PM
Dufrain
Oct 17, 2004 07:46 AM
