Throttle sticks to the floor PLEASE HELP!
Old Aug 8, 2007 | 12:03 PM
mike_ward's Avatar
Its a 96 ctd 12 valve.
The throtle sticks when its 1/2 throttle or more,
The return spring is there and working as should, The lever is very stiff when you push it to WOT and try 2 pull it back, what is causeing this in the pump?? is it a ez fix or a high dollar one?
Old Aug 8, 2007 | 01:58 PM
CR785's Avatar
Did you move your fuel plate or anything? Almost sounds like your governor lever is getting stuck on the bottom of the fuel plate. Either that or maybe the linkage in the pump got screwed up. Hopefully someone that has had this problem before will chime in.
Old Aug 8, 2007 | 02:57 PM
mike_ward's Avatar
no, I did nothing. I was getting ready to start modding it.
It took off across the gas station in to there flowers before i got out of the confused/ shock and pushed in the clutch and shut the key off.
If you push it more than half way it sticks badly, It will some times stick for a sec thin let loose but lately when its down you have to pop the hood and pull it back up with your hand. weird Hugh?
Old Aug 8, 2007 | 09:15 PM
mike_ward's Avatar
cr787 was the winner on that one. The gov arm WaS going under the STOCk un tuched plate, Wierd!
Old Aug 9, 2007 | 12:02 PM
CR785's Avatar
I am glad you got it fixed, i was hoping that was all that was wrong with it and nothing more serious.
Old Aug 9, 2007 | 01:01 PM
mike_ward's Avatar
it inda makes me wonder why this happend, It was totaly untuched 12 v. with 120K
Old Aug 9, 2007 | 07:29 PM
TIMMY22's Avatar
Mike,
Read this post.
https://www.dieseltruckresource.com/...light=canz9700
Old Aug 9, 2007 | 09:42 PM
mike_ward's Avatar
Ya, thats another thing, my cable has like two wire's left. gonna goo very very soon. Im gonn a call the dealer and ask if my truck is covered.
TIMMY22 thanks for sending that post.
S2CPitts
Sep 19, 2012 07:21 AM
jaypry
Jul 26, 2008 01:21 AM
Silver 002
Apr 29, 2008 11:53 AM
roberts11260
Jul 16, 2006 11:57 AM
belfert
18
Mar 24, 2004 11:53 PM
