Throttle Springs
Old Feb 2, 2006 | 08:50 PM
AllPlay's Avatar
Throttle Springs
My truck is starting to get really jumpy on rough terrain or between shifts. I see the spring at the end of the cable but should'nt there be another on the arm below the pump. It is really starting to get hard to drive. Also I noticed if the truck is not running and you push the go pedal it will stick where it's at, but this is only when it's not running. If it's running and you push it all is O.K. Thanks for the help.
Old Feb 3, 2006 | 09:40 AM
infidel's Avatar
Hard pedal when not running is normal.
Should be two springs. Go to a hardware store for a replacement.
Old Feb 3, 2006 | 03:57 PM
AllPlay's Avatar
Thanks for the info. I found a good drawing that showed the two springs. Just have to find the replacement now.
Jordan5687
Jan 29, 2015 10:32 AM
Dan70
Mar 5, 2014 04:10 PM
53 willys
23
May 19, 2008 06:14 PM
95turbo4wd
Dec 12, 2007 05:59 PM
bigred496
Oct 22, 2004 07:16 PM
