Those of you with the tick, look here.
Old Mar 27, 2007 | 05:59 AM
~Angry Tractor~'s Avatar
How many miles on the truck?
Old Mar 27, 2007 | 07:47 AM
satburn's Avatar
Originally Posted by TravisG
Glad to see you got it figured out. That first pic is just downright scary. It looks like in the first picture you were already prepared for the worst and started on your counterfit money ring!!!!
Originally Posted by LanceD
yeah, I was going to mention something about photocopying money...
No, no... nothing like that. But, I do have a nice pyramid scheme, err I mean business opportunity, that I'd like to share with you guys.
Originally Posted by red70ragtop
How's that rod journal? Looks suspicious in the picture, but it could be the light from the flash, or just goop/debris.
Looks bad doesn't it? If I didn't know any better, it looks like it was covered in duct tape... oh... wait. Good eye though!
It's good, I just wrapped it up in case I got too wild with the hone. Bearings were great, I plan on checking them with a little plasti-gauge to make sure things are still in spec.
Old Mar 27, 2007 | 07:49 AM
satburn's Avatar
135,xxx ish, or its 137,xxx ish.... Yikes, that's bad! I've been out of my truck for so long I've forgotten the odometer reading!!! I got to get this thing back together soon!
Old Mar 27, 2007 | 01:35 PM
Rare1's Avatar
What have you done to prevent this from happening again?
Old Mar 27, 2007 | 02:02 PM
CIN'S DODGE's Avatar
Mrs. missin on a mission & keeper of the can
Satburn, how bad was your tick?
Old Mar 27, 2007 | 02:14 PM
Dr. Evil's Avatar
Originally Posted by ratsun
Do the cooling jets look ok?
This would be a good time to replace them. Did Cummins use plastic oil squirters back in 96?
Old Mar 27, 2007 | 03:38 PM
satburn's Avatar
You mean besides sacrificing several virgins? My engine guy came over with a battery of measuring devices to make sure the bore was good. There is a slight taper now, but he said it was still in spec. I trust the guy, he's worked on these since he was little and his dad did before that. He's the "go to" guy in the area. So, with the bore in good shape that leaves:
1) Piston, which is getting replaced, so we're good there now.
2) Injector, which since this occured prior to my owning it, has now been replaced, but they will all be popped tested to make sure...
3) Cooling jet, which I'll test with the handy idea I got of using a bug sprayer filled with oil.
4) Bearings, also checked and look good.
Those things checked I would think I'd be good to go. Other than the obvious abuse I'm going to put it through truck pulling...
Hold on, let me go out and fire it..... ahhhh MAN! Well, ugh, it was pretty loud at times, but would sort of melt into the other sounds of combustion after it warmed up. What was funny is it would sort of come and go. Some days worse than others, but always the worst when it was cold (which makes sense now). I've got a vid of it starting with the camera up on the passenger side and I can hear it in the vid, but that's because I'm really listening for it.
http://satburn.com/pull/435s.wmv
When you listen to it, take your knuckles and thump them on your desk about 4 times a second, that's your pattern to listen for. Now in the vid, its kind of bad because the exhaust is rattling against the bed side, but listen for AFTER I rev it and the engine is coming down in RPM, you can hear it plain as day there, you'll hear it go up and then tick, tick, tick, tick as it's coming back down. That's it.
Plastic? Better be some tough stuff. Mine are metal in my 97.
Old Mar 27, 2007 | 08:04 PM
TravisG's Avatar
Your motor guys name isn't Kurtis is it?
Old Mar 27, 2007 | 08:44 PM
satburn's Avatar
Negatory, Todd is his name, who's Kurtis?
Old Mar 28, 2007 | 12:01 AM
TravisG's Avatar
A buddy of mine that works on equipment down around Owensville. I was just checking. He is pretty slick. I used to live in St. Louis and run around w/ a bunch of guyz from around there. We might know a couple of the same people.
Old Apr 3, 2007 | 11:21 PM
satburn's Avatar
FYI: Honing sucks. Honing the back cylinder while the block is in the truck is as fun as burning yourself with a propane torch. At last though, they are all done and the shiney. Now if those pistons would hurry up and get here!
MTC
Jan 2, 2008 07:53 PM
stirpicult
34
Nov 15, 2007 08:50 PM
59FORD
Aug 10, 2005 08:09 AM
haulywood
Jun 10, 2005 11:27 PM
OHFarmboy
Dec 27, 2003 11:36 PM
