is there a seal ....
is there a seal on the back of the power steering pump ?? i have a very annoying oil leak and thats where it seems to be coming from. the power steering oil level is fine though so im not sure what is going on. any help ? scott
that sounds like the seal leaking on the vacuum pump - motor oil.the vacuum pump is driven first then the shaft goes threw and drives the steering pump,the pumps are bolted together.just do a search on vacuum pump,you should find alot of info...
Re: is there a seal ....
RTillery
Feb 7, 2009 08:46 AM
pwrtripls1
Jan 7, 2008 08:55 PM
dieseljerk
Jul 8, 2004 07:23 AM
