TC lockup switch problem
Old Nov 29, 2002 | 05:47 PM
cowpie's Avatar
I'm back to drink from the well of knowledge again. I installed the TC lock-up switch today, but no difference in trans. performance. I remember some one in another post mentioned that some 96 models need to have the computer re-flashed in order for the switch to work. Anyone know what this involves or if I can tell if mine needs this?
Old Nov 29, 2002 | 06:22 PM
Rammin On's Avatar
Re:TC lockup switch problem
Did you tap the right wire?
Old Nov 29, 2002 | 06:45 PM
98rammer's Avatar
did you also do the jumper wire in the engine fuse box?
Old Nov 29, 2002 | 07:39 PM
cowpie's Avatar
I think so to the former and yes to the latter. According to the directions, the orange/black wire is the one to tap. And I put the jumper in the trans. relay hole. I am supposed to leave the relay out, correct?
Old Nov 29, 2002 | 08:45 PM
BoldtsWagon's Avatar
On the 97 there are two orange/black wires. The second one is the intake grid heater indicator light. Check the 96 wiring diagram.
Old Nov 29, 2002 | 09:17 PM
98rammer's Avatar
there are at least 3 that i know of on my 98 (within the 3 harnesses at the &quot;box&quot; mounted on the firewall). if i remember right, it's B11. if you do have the right wire, then i'd say that you need the computer flash. <br><br>Tom
unioncreek
Jul 12, 2013 08:34 AM
cowboykilla235
Feb 17, 2013 03:02 PM
93dieselZak
Jun 16, 2011 06:10 PM
JQmile
Sep 15, 2010 10:43 PM
Cowboy_Customs
May 6, 2008 09:39 AM
