TC Cable
Old Nov 24, 2010 | 07:25 PM
Ram95's Avatar
TV Cable
My trans has been shifting funny. From a dead stop it will start to roll then when I give it throttel it will go a little then go flat and RPMS go to 2000 and a little above and then it shifts. How ever if I let of the trottle and then push down on the trottle it is fine and goes like it should and shifts through the gears fine. When this first started I pulled the pan and changed the filter and fluid. The fluid was good did not smell burnt no shavings in the bottom of the pan.
I have done some searchs on here about trans problems and from what I have read I think it may be a sticking TV cable. So I want to check that first. Just want to know where it is located so I know that I'm looking at the right thing.
Old Nov 27, 2010 | 08:29 PM
cj360trider's Avatar
this from any dead stop or pretty much right after start up?
Old Nov 28, 2010 | 06:31 AM
infidel's Avatar
Sounds like bands need to be adjusted.
Instructions> http://dodgeram.org/tech/transmissio...T_band_adj.htm
Old Nov 29, 2010 | 10:12 PM
Ram95's Avatar
Infidel
Thank you for the info. I adjusted the bands and it shifts great now.
90firstgen
Apr 13, 2008 05:48 AM
Kirk T
Sep 20, 2006 07:19 AM
hellotbone
Oct 7, 2003 06:54 AM
sixtogo
Mar 12, 2003 08:29 PM
Jbolt001
Oct 31, 2002 11:06 PM
