Symptoms of 5th gear nut failure?
Just wondering as I have seen quite a bit posted regarding the 5th gear nut failure on NV4500 transmissions. Are there symptoms prior to this failure that people have noticed? Reason I ask is I am hearing gear noise in 5th gear, sort of a cross between vibration and "grinding." I have always heard a little gear noise, but lately it's gotten a bit more noticeable. Just wondering what you all think. Thanks for your help!
Loose Nut Syndrome
It was no big deal for me either ,, Just driving down the highway at 70MPH let off the throttle and all of a sudden,,,NO 5th gear,,,,,,,In My 5th gear case,, I have had my truck for almost two years now,,since I have had my truck it has been hard to put in second gear ,,, I could come to a complete stop,, And TRY to put it in second gear,But it would not go ,as if the clutch was not disengaging, So I would just put it into third first,, Then go to second and it would go right in,,,If the truck was rolling ,it would go right into second. Now that I have replaced the fifth gear nut with the new,Dodge TSB nut,, IT goes right into 2nd gear ,,,
Everything is perfect now I hope the Dodge fix works!!
FYI, The Transmission does NOT have to come out to repair The 5th gear problem,
LemonDodge
Sep 16, 2010 07:33 AM
wadecool
Nov 13, 2006 12:37 AM
