Surface rust on...
Old Jan 8, 2007 | 03:38 PM
TravisDj's Avatar
Surface rust on...
Turbo, Exhaust manifold, and motor. Is there anything I can do for it, or does it really matter? Thanks for all you guys help. I love this truck.
Old Jan 8, 2007 | 08:45 PM
9512vCTD's Avatar
my 95 is the same way, its not a show truck so it doesn't really matter how pretty it looks under the hood but i can already see the problems ill run into when i go to try to remove the manifold, turbo etc. for mods down the road..
Old Jan 8, 2007 | 09:21 PM
realtreehunter's Avatar
its just from the heat but you can cure it, give me all the rusted parts and replace them with new and never drive it lol
Old Jan 8, 2007 | 10:39 PM
kawi600's Avatar
sandblast it to bare metal and use high-heat paint? Youll want something good for that area though since it will go over 1500 easy enough. Mcmaster-carr has some 2500F paint but it aint cheap $_$
Old Jan 9, 2007 | 09:20 AM
chevummins's Avatar
I painted an exaust manifold on a gas engine with high heat oven paint. I got it from a place that sells bbq pits and such and they use the paint on those. I am not sure how well it would hold up, but I am sure sand blasting to bear metal would be a must with anything of that nature.
Old Jan 9, 2007 | 10:29 AM
CarlJensen's Avatar
I used rust cure (phosphoric acid, the stuff in Coke) on all the exaust parts that I wanted to keep in reasonable shape. It turns them black and gives a light coat on them to slow down rust. Won't work forever, nothing will, but it slows it way down and can be re applied any time you wish.
Old Jan 9, 2007 | 11:22 AM
kawi600's Avatar
yeah thats a good idea also. Some of the stuff contains zinc which will turn the surface white, so be sure which type youre getting.
ib516
36
Apr 17, 2007 09:48 PM
Dodge Trucker
Mar 21, 2006 04:37 PM
ROCKHEAD
Mar 12, 2006 07:48 PM
RottnRam
Sep 8, 2004 12:18 PM
2500_dan
Aug 14, 2004 11:07 AM
