Stock Governor Spring Specs.
Old Jan 8, 2007 | 12:08 PM
schaef_12's Avatar
Does any one have Specs on where to set the retainer nut for stock settings, or is every pump different? The reason I ask is because I tried doing the washer mod and the pump "hung up" so i retuned it back to stock but the first nut I took off, the clicks didn't get counted accuratly. So I made sure to count the second one "right" and put them both back on to what the second one was origanally. It seems to run fine and Idle like it did before, but I am a worry wart.
Old Jan 8, 2007 | 02:32 PM
JKM's Avatar
JKM
If it is running fine , then you got them spot on , no need to worry
Old Jan 8, 2007 | 02:40 PM
Txwelder's Avatar
agreed, nothing to worry about.
Old Jan 8, 2007 | 06:54 PM
Forrest Nearing's Avatar
yup, if the tach isn't bouncing and it feels good, it's good
Old Jan 8, 2007 | 07:44 PM
schaef_12's Avatar
Thanks guys, it's just that after you tinker with something you always end up second guessing yourself.
Old Jan 8, 2007 | 08:33 PM
only if you care about what you're tinkering on!
Old Jan 9, 2007 | 05:59 AM
Txwelder's Avatar
Its not like there are any torque specs when installing the spring kits. As long as they are in there and the truck starts and idles correctly you are good. Nothing should be coming apart, as long as you put it back the way it came out, if that is what you are worried about.
Old Jan 9, 2007 | 02:59 PM
schaef_12's Avatar
That's what I am worried about, I only know for sure how the second retainer nut was positioned, so I set them both back to how the second retainer nut was origanally located at 5 clicks. But I would imagine that both would have to be the same amount of clicks in and it doesn't matter how many clicks that is as long as it Idles?
Old Jan 9, 2007 | 11:26 PM
Fueling around's Avatar
Factory setting may be a click different from side to side. As long as the truck runs the same I wouldn't sweat it.
Installing a GSK may require a lot of fine tuning with amount of clicks to get the proper throttle response & minimize flutter.
92smokin blacky
Oct 3, 2010 07:21 AM
06RAMCTD
0
Dec 19, 2006 04:15 PM
Monty
Apr 1, 2003 02:15 AM
Alec
Feb 5, 2003 06:23 AM
dieselinveins
Nov 15, 2002 10:36 PM
