Stuck Wastegate
Old Dec 19, 2007 | 08:04 AM
WVAussie's Avatar
Stuck Wastegate
I am in the process of installing gauges. I took the turbo off to replace the gasket to the manifold and drill the pyro hole. While I had it off I noticed that the wastegate was rusted tight it is stuck in an open position. I guess I'll see what boost its making soon. My guess is its been like this for a long time ,how much would this have been affecting the performance? The rest of the turbo seems to still be in pretty good shape so is a stock exhaust housing replacement a practical fix?
Old Dec 19, 2007 | 02:22 PM
MikeR's Avatar
It affects performance alot...makes for a laggy bottom end.
New wastegated housings are expensive for a stock HX35, if you're gonna buy new, then get a bigger housing like a 14cm.
Or the cheapest way, you can always find a good take off 12cm housing from the west, they don't rust up out here.
sallyman1
Feb 10, 2008 06:17 PM
Baja
Jan 29, 2008 08:17 PM
Sawyer1
Jul 17, 2006 02:19 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
