Wastegate stuck?
Old Jul 12, 2006 | 12:32 PM
Sawyer1's Avatar
Question Wastegate stuck?
Is it possible that a wastegate can stick partially open? My boost pressure seems to be slow building and doesn't go over 25psi even holding it at wot.
Is it hard to remove to check it visually?
Thanks for any responses and have a great day.
Old Jul 14, 2006 | 04:31 PM
Sawyer1's Avatar
Ok. I have taken off the line to the waste gate and applied shop air to it and it seems the gate opens at 20 - 22psi. The lever seems to move about 1/4 of an inch. Is that enough? Is there no practical way to actually see if the waste gate is opening and closing all the way?
Old Jul 14, 2006 | 04:34 PM
Gotlift01's Avatar
That sounds about right.......they usually open around that PSI........I'd say it's working just fine.
~Nick
Old Jul 17, 2006 | 02:01 PM
Sawyer1's Avatar
Thanks for the reply Nick. Why does it take until 3rd gear and really walking on it to get any real boost? Is something else holding it back?
Old Jul 17, 2006 | 02:08 PM
jimk's Avatar
could the low gears keep the boost down until the higher gears load up the engine, and the governor doesnot pull the fuel out as easy. That could just be BS anyway it is just an idea Jim
Old Jul 17, 2006 | 02:19 PM
Gotlift01's Avatar
I'm kinda agreeing with that!! The first 2 gears are just to get you rollin, once you hit third it gives it a chance to actually work the motor a little more to gain more boost.
Now if you were to hook onto a trailer, you'd get a lot higher boost numbers in 1st and 2nd because you have a load. Or even if you were to stick larger tires on your truck, you'd see higher numbers also.
That's why some guys are saying swaping from 3.54's to 4.10's actually makes the truck slower. The 3.54's add a bigger pull to the motor to get the turbo to kick in sooner. Or at least that is my theory anyway
~Nick
sallyman1
Feb 10, 2008 06:17 PM
Baja
Jan 29, 2008 08:17 PM
bowtiestrkrsmkr
0
Nov 3, 2006 11:15 PM
ataboy9026
Feb 22, 2006 05:09 AM
MoparRiggan
Oct 13, 2005 11:54 AM
