Stock thickness head gasket with mods?
Ive been fighting with some really bad fuel economy on my truck. Its down around 11mpg with mixed driving.
I recently had the pump rebuilt so I know its not that. The injectors and the valve lash check out too.
It seems like the issues started when I had the head gasket replaced. They decked the head .015 and used a .020 gasket.
I know when you deck the head you need to be careful of valve protrusion and thats part of the reason for a thicker gasket. The other part has to do with optimizing for boost. Problem is the truck is driven easy around town a lot and the mileage is awful. I think the reason for that is the lost compression.
Does anyone here run 500-600hp on a stock thickness gasket? Do you think studs and orings on a stock thickness gasket would hold up to that kind of pressure with 65psi?
Ive got hamilton's springs on there. I think theyre 110lb. and Ill probably keep the 3K gov springs in it so Im not worried about valve float.
I got some other feedback too that makes me think this should be a safe combo at 650hp which is what my goal is on the truck.
I think the loss in compression is whats killing my low end power and economy.
Self-inflicted wound there.
dieselboy59
Jan 30, 2009 03:57 PM
tristan21
Jun 19, 2007 04:57 AM
Conn
Dec 29, 2006 06:30 AM
