Stiff Throttle half way down
My throttle pushes easy for about the 1st half, then it just hits a spot where it's a lot harder. I thought my foot was going to fall off on a 4 hour road trip 2 weekends ago!
Somebody told me it had something to do with the rack travel and AFC even with running no plate and suggested a get a boost elbow. I don't really understand all that....anybody that can translate into English for me?
Are you getting any boost signal to the AFC? They fully retract after a few pounds.
A boost elbow is going to put more air into the engine Stay that way until you get some gauges.
Low boost is only going to make lots of smoke if you have the fuel to make it.
When I first start my truck I hit a stiff spot when I first depress the pedal but it doesn't seem as bad when driving. I'd checkout you linkage and verify it is not binding. There are directions for adjusting the linkage too:
http://www.dodgeram.org/tech/dsl/T_Cable/diesel_tc.htm
Mine was bucking on me till I replaced a few springs that were missing. With the springs missing the pedal was too sensitive and with the springs in it solved bucking but gave a stiffer feel to pedal. I got the springs from Cummins I believe for around $20. But....that's another linkage issue. When your looking at linkage verify all your springs are connected and not worn out.
Dave
Dave
Subliminal
Feb 6, 2011 08:05 AM
Ranger391
Jul 5, 2010 06:54 PM
