Steering box want a good one
Old Feb 20, 2008 | 11:41 PM
claywake222's Avatar
Well I have had it, gone through 5 boxes in 5 months, looking at the 841mx , does anyone like or dislike this steering box? I am looking for easier feel.
And who to order from?
thanks.
Old Feb 21, 2008 | 02:23 PM
justme-'s Avatar
How about a DSS stabilizer?
the other boards I used to follow didn't seem to find any one box really any better than another. They are fairly easy to rebuild yourself too, and the parts are readily available from both the ******* and other shops- it's a common box.
Old Feb 21, 2008 | 10:46 PM
Today I ordered the stabilizer and a quick ratio box, well see if that helps.
thanks
Old Feb 22, 2008 | 11:23 AM
Hayseed's Avatar
anyway of using a third gen box? I like the ratio and feel... if I could just get that on my 2nd gen!!!
Old Feb 22, 2008 | 11:41 AM
kawi600's Avatar
Ive been happy with my PSC box and DSS so far.
Old Feb 25, 2008 | 04:40 PM
walexa's Avatar
I love the 841mx.
Long story short: I got a bonus at work and ordered an 841mx. Truck steered real light........felt about like drive by wire, took some getting used to. Anyway, only thing wrong is that the truck would not turn lock to lock sitting still on pavement. I called PSC and they recommended an 841m over the 841mx, so sent me one free of charge. I install it and did not like it compared to the lightness of the mx........and still not turning lock to lock, so it wasn't the box. I liked the mx so much that I took the m off and put the mx back on. That's been 3 or so months and it's awesome. It does take a little bit of getting used to but it steers better than my wife's civic!! So much for long story short, lol.
Waylan
Old Feb 26, 2008 | 03:12 AM
Originally Posted by walexa
I love the 841mx.
Waylan
Waylan, do you have the support installed ? is your pump up to the task?
I should be getting my MX in about a week or so.
Phil
Old Feb 26, 2008 | 07:14 AM
walexa's Avatar
Phil,
I had already installed a DSS on the factory box, so yes, I have the support installed. The pump is a whole nother story.
Since it was not turning lock to lock while sitting still on dry pavement (it would turn 2/3 of the way towards full lock on either side, but not ALL the way), I got to reading and found a website that showed how to modify a factory steering box for more pressure. I did the mod to the valve, put it back together and it worked great. The next morning I pulled in to work and worked the steering lock to lock about 4 times just to make sure it was working and BAM......something broke. Now I had no power steering and no assisted brakes. I knew it was the pump. Replaced pump with napa pump that does the same thing. I have another valve to put in it from PSC that will up the pressure to a safe range, just haven't made time. It's not really a big deal either way.
Waylan
Old Feb 27, 2008 | 02:12 AM
Phil,
Waylan
Let me know when you put your valve in and how it works for you.
Could you send me a link where you got the info from?
thanks.
Old Feb 27, 2008 | 08:49 AM
walexa's Avatar
Here is the power steering pump mod link:
http://westtexasoffroad.homestead.co...rsteering.html
I am afraid to put the higher pressure valve in right now since if it breaks the pump it will require time to change the pump out again. The valve was only $5 from PSC, so if it works it will be a cheap investment.
Waylan
Old Feb 28, 2008 | 02:31 AM
Waylan
Thanks Waylan.
Old Feb 28, 2008 | 10:15 AM
wcbcruzer's Avatar
Is there something causing your steering box's to go bad? Were the replacements just not any good?
Old Feb 29, 2008 | 05:23 AM
Not sure they all had stiff steering, and play about 4" or so.
I have ordered the stabilzer for the box, just waiting for it to get here?and a new box from PSC. The one I am using now has very easy steering, just about 5" play .
I8SMK4U
Jun 13, 2013 12:13 PM
kX500
60
Apr 10, 2013 03:34 PM
Dieseldog800
16
Jun 19, 2008 10:58 AM
Tommy93w350
Jun 25, 2007 09:52 PM
04ctd
Oct 5, 2006 08:27 PM
