Starting Problems
Old Jul 28, 2003 | 01:33 PM
brad363's Avatar
Starting Problems
truck runs fine after it sits for awhile it wont start unless i take the fuel cap off. then it starts just fine. what do you think ???
1997 3/4 diesel truck drw
thanks much
Old Jul 28, 2003 | 03:34 PM
sherod's Avatar
Re:Starting Problems
First, crawl underneath and reach for the fuel lines in the top of the tank. Make sure that the vent is clear and not covered with mud or something. I expect you will find a vent blockage to be the culprit. Do you have a guage for the fuel pressure? If not, suggest you make up a temporary guage to see what you have when it is working correctly. Good luck,<br>Ed
Old Jul 28, 2003 | 03:40 PM
Smokee's Avatar
Also check the rubber fuel lines above the starter. There should be NO moisture there.
fourthandgoal
88
Dec 27, 2011 05:39 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
doodah
17
Dec 17, 2002 12:55 PM
