Starting problem...
Old Mar 9, 2009 | 05:26 PM
97dodge12v's Avatar
Starting problem...
I had this problem a while ago, my truck will fire then die right away, and do it about ten times, and then will finally fire, so i did a lot of reading on here and found most people say to replace return fuel line, so i did with diesel grade fuel line, and it was back to normal, started fine and all, now it is back again... any other ideas what it could be? thanks alot.
Old Mar 9, 2009 | 06:08 PM
infidel's Avatar
Idle too low?
Don't trust the dash tach.
Instructions> http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
Old Mar 9, 2009 | 06:38 PM
sshort's Avatar
check the supply line where it comes out of tank they get rusted & suck air mine did that it would start & die & then finally would not run all together until i found the rusted line
Old Mar 10, 2009 | 10:40 PM
97dodge12v's Avatar
no idle is good, and i know there is no rust on the truck, it has under 90k miles, and has was owned by and grandpa and i checked it all out.... any other ideas?
Old Mar 10, 2009 | 11:21 PM
Lil Dog's Avatar
Could be a leak at the fuel heater/sediment bowl gaskets below the lift pump. I also had a problem with my lift pump getting weak and replaced it.
Old Mar 11, 2009 | 10:19 AM
infidel's Avatar
Big reason I quit replacing just the short return hose behind the engine is that often in the struggle to get the hose on blind the metal line on top of the bell housing will get a small crack where the hold down tab is welded on.
Almost impossible to see if it's leaking there, have to go by feel.
If this metal line leaks hard starting doesn't usually happen until you're lower than about 3/4 tank.
Now I always run diesel rated hose all the way from engine to tank.
Not only is it an easier job it also eliminates future supply system problems.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
Palmetto_kid
Apr 25, 2003 05:14 PM
turbospl311
15
Jan 21, 2003 12:39 PM
