Stalling in gear
Old Sep 21, 2005 | 03:04 PM
turbo thom's Avatar
That is due to the engine not runnin.
Old Sep 21, 2005 | 04:33 PM
eng208's Avatar
What is due to the engine not running? I am confused.
Chris
Old Sep 21, 2005 | 04:51 PM
turbo thom's Avatar
When the engine is not runnin, the pump will offer resistance. Start the engine and feel the difference. If the throttle linkage does not move freely with the engine runnin, then you have an issue with the internals of the pump. Check , like has been said, the spacers where the rod goes into the pump. They could be worn and be in need of replacement. Don't check the linkage without the engine runnin. You'll think the pump is bad.
..PT..
Old Sep 22, 2005 | 04:24 PM
Grantjd's Avatar
There is quite a bit of resistance in the throttle linkage as noted, and it does go away when the engine is running. All that seems normal.
What spacers are you referring to where the rod goes into the pump? Im not seeing any mention of that....
cowboykilla235
17
Feb 1, 2013 08:05 AM
BrandonScott
Jul 11, 2012 07:04 AM
hotmod660
Dec 15, 2006 09:46 AM
SmokinFive9 4x4
Sep 17, 2005 11:20 PM
