Stalling
Old Mar 15, 2005 | 05:22 PM
suzukiZrider's Avatar
Stalling
i am looking at a truck that the owner said ever sence the reacall on the throttle cable sence he got it replaced when he starts it in the cold it stalls but once warm it runs fine is this a problem also it has an oil leak around the timing chain area what could this be and is this a problem the ac dosnt work i dont care though prolly needs a new compressor or somethign of the sort and the cruise dont work could this be a sign of future problems or is this just with the cruise thanks guys
Old Mar 15, 2005 | 06:12 PM
G1625S's Avatar
No timing chain on a cummins---all gears in there. An oil leak in that area could point to KDP damage....best look real close at this one. Cold stalling is prolly just an idle that's set too low---especially if it showed up right after someone was fussing with it.
Old Mar 15, 2005 | 07:28 PM
timing cover sorry bout that
Old Mar 16, 2005 | 02:02 PM
anyone else got any suggestions or info
Old Mar 16, 2005 | 04:41 PM
out_drsman's Avatar
You might check that the overflow valve has been replaced:
Precision Diesel Injection and Turbo Inc.
Marty Tompkins
888-734-7349
$35 + $7 shipping and handling.
Also check the fuel lines to see if they have been replaced. Its very possible that they have started to crack.
These are just two of the things that I remember seeing on this site that cause this type of problem.
Old Mar 17, 2005 | 05:35 AM
what do you think is more likely the kdp damage or just a bad seal he said he thinks its the seal and he has a new one its just not put in yet
Old Mar 18, 2005 | 03:03 AM
halerazor's Avatar
my timing cover leaks too but thats because i used the old seal when i tabbed it and then started using synthetic oil. it all depends on how bad its leaking if its just oily around the bottom i would say its the seal. if theres a puddle underneath its the kdp
Old Mar 18, 2005 | 08:36 PM
if it unfortunatly was the kdp would it still run and its only a little oily not liek a puddle
Old Mar 19, 2005 | 01:20 AM
halerazor's Avatar
it's probably the seal then. buy tst's kdp tab kit it comes with the crank seal and rv sealant so then you can fix the leak and the kdp
Old Mar 19, 2005 | 07:29 PM
if you leave it overnight it will leave a spot about the size of a quarter so would you say seal or kdp
Old Mar 20, 2005 | 01:40 PM
halerazor's Avatar
its one of the seals the kdp would leak alot more
Old Mar 20, 2005 | 01:53 PM
well then thats good news how bout the cruise control and the ac and it idles around 500 rpm thinks it needs new injectors if thats not it what else would it be
Old Mar 20, 2005 | 02:30 PM
Hemi Cat's Avatar
If the idle is 500 rpm when warm, it's too low. bump it up to about 750. The stalling and hard start when cold could be the low idle or the timing needs to be bumped up. The no A/C is probably the refridgerant is low or gone. Find the leak and fix it then recharge it. The cruise has electrical and vac. make sure the vac lines are good and the fuse is good, then check the switches and cable. Does your tach work?
Old Mar 20, 2005 | 04:50 PM
yes the tach works
Old Mar 21, 2005 | 05:41 AM
i dont wanna sound stupid but how do you bump up the idle
