Speedometer/Odometer Problems
Old Sep 28, 2011 | 07:00 PM
jbix12v's Avatar
Speedo/Odo aren't working on a 1998 12v project truck. What are the most common reasons behind this so I can go through and check them out. Any help is greatly appreciated. Thank you!
Old Sep 28, 2011 | 09:00 PM
98fargo's Avatar
Check the vss on the rear diff, and the wires to it
Old Sep 29, 2011 | 02:57 PM
pearl's Avatar
The 98 peedo connects to the rear diff?
Old Sep 29, 2011 | 03:33 PM
98fargo's Avatar
Yep, the vehicle speed sensor is mounted on the top of the diff, one little bolt to take it out, common for the wires to get eaten by rocks and things, there is a resistance reading for the sensor can't think of it off the top of my head though. Maybe someone else will help out with that
Old Sep 30, 2011 | 09:59 AM
infidel's Avatar
If I'm not mistaken the '98 uses two VSS.
One on the differential is is for under 30 mph, the one on the t-case or tranny is for higher speed.
Old Sep 30, 2011 | 01:02 PM
98fargo's Avatar
Mine only has the one in the diff, replaced it once because of the same issue, very well could be variances through the year though
Old Oct 1, 2011 | 04:53 PM
pearl's Avatar
Well it doesn't work at any speed, and if there's something on the bell housing they guys who replaced the stock tranny with the built one could have gotten something wrong. They said they reused the old sending unit cause it was working. Just moved, soon as I clear some crap out of my garage I'll crawl under it and look both places. It worked fine for 300 miles after tranny swap.
spitzair
Aug 28, 2006 01:25 PM
Mosh
14
May 28, 2006 06:41 AM
mytrucksaslug
May 26, 2006 10:00 AM
ouchman
May 9, 2006 08:50 PM
AggiePhil
Mar 15, 2005 08:20 PM
