speedo gear for 265/75/16 tires
I need to get my speedo corrected for my 265/75/16 tires. The PO had some huge meats on the truck and now the speedo is 8-10 mph off. I have been searching and cant seem to find the gear number that I need.
Thanks,
Tony
Thanks,
Tony
Try this web site.
It will calculate what gear you need, you just need to enter the tire size and rear end gear ratio.
http://www.juric.org/mopar/tools/transgear.php
It's been quite a long time since I last made one of these but I **think** a 3:54 rear end uses a 31 tooth gear - it's either that one or a 29. I recall it should be green in color. When you change the gear, just remove the bolt that holds the adapter to the T-case and pull straight out without twisting (O-ring can get cut when twisting the part).
cLAYH
Sep 30, 2009 08:43 AM
Rednecktastic
13
Jun 6, 2009 10:51 AM
1320
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
