Speedo died
Old Aug 22, 2008 | 01:17 PM
1fatxl's Avatar
Speedo died
My speedo just decided to crap out. Everything else on the dash is working fine, just the speedo. I tried cruise on the way home and that worked, odometer is clicking off the miles too. I was removing some trees this morning and the rope broke and flung itself under the truck, is therre a wire under there somewhere i coulda taken out and killed the speedo?
Also after shutting off at the store to get a tougher rope, it would not start had to tighten the connections under the hood to get it to light. Is ther a wire there i coulda screwed up?
It is a 96 2500 4x4 stone stock.
Old Aug 22, 2008 | 03:55 PM
patdaly's Avatar
I would almost bet that your speedo died, because the Odo still works.
That being said, there is a sensor on the rear axle and also one on the T-case I believe on your 96.
Check the center front top of the rear end and the side of the T-case.......
TJE
Mar 9, 2011 06:48 PM
redpoint5
15
Dec 13, 2009 12:27 PM
Tommy93w350
20
Nov 1, 2005 11:07 PM
chdiesel
Oct 31, 2002 03:22 PM
