smoky, rough starts when cold
Old Dec 16, 2010 | 06:31 AM
fruitcakesa's Avatar
When the temps drop into the 30's and colder my 95 CTD starts really rough, lumpy and smoky.
Once it warms up it smoothes out with full power
It seems worse than in prior years.
The truck is stock with about 180k miles.
Any thoughts out there
Old Dec 16, 2010 | 08:08 AM
patdaly's Avatar
Probably grid heater?
Check it with a voltmeter...............
Old Dec 16, 2010 | 08:15 AM
Where can I find the contacts to test it?
Old Dec 16, 2010 | 10:07 AM
infidel's Avatar
Click> http://dodgeram.org/tech/dsl/trouble...niford_htr.htm
If the grids check out my next guess would be your injectors are worn.
Old Dec 16, 2010 | 11:26 AM
cj360trider's Avatar
Plugging the block heater in wud prolly resolve the cold start problem
Old Dec 16, 2010 | 12:21 PM
patdaly's Avatar
The actual heater is between the intake manifold and the tubing running to it. It is a square aluminum block, about 3" x 3", and will have 2 fairly heavy gauge wires leading from 2 terminals down to a solenoid pack on the drivers inner fenderwell. You can check there for 12V with a VOM or test light.
Infidel, do you have another link, that one appears to be broken.
Old Dec 16, 2010 | 12:24 PM
This is with the block heater plugged in!
Old Dec 17, 2010 | 12:20 PM
infidel's Avatar
It appears the entire dodgeram.org website isn't working.
Hopefully it's just a server problem, too much info there to lose.
Grid heaters in action!!!
No wonder they draw so much juice
Old Dec 17, 2010 | 12:36 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
That is a GREAT Photo Bill!
And I have seen people argue here that it is relatively safe to use a shot of ether when you need it even though it will hit that long before it reaches the combustion chamber, blowing the intake off the engine.
Old Dec 18, 2010 | 06:58 AM
chariotdriver's Avatar
Do the grid heaters always get that hot or did you leave them energized a little longer than normal?
quite impressive
MARF75
Jan 24, 2012 08:08 AM
taneum
Oct 22, 2010 10:19 AM
97catintenn
Jan 7, 2010 11:33 PM
Calgary Roofer
Jan 3, 2008 11:52 PM
DieselMachine
Jan 23, 2004 09:20 AM
