small puffs of black smoke at WOT.
Old Sep 6, 2005 | 07:15 PM
plow's Avatar
what would cause small intermitent puffs of black smoke at WOT.
Old Sep 6, 2005 | 07:41 PM
Dr. Evil's Avatar
Youve got 4 trucks listed - which one are you talkking about?
Old Sep 6, 2005 | 07:56 PM
plow's Avatar
the 97 model 12 valve
Old Sep 6, 2005 | 07:59 PM
Dr. Evil's Avatar
Well, youve got a 100 plate slid all the way forward and the AFC housing slid too - that could have something to do with the smoke, dont ya think?
Old Sep 6, 2005 | 08:05 PM
phox_mulder's Avatar
Hey now, there's no need for sarcasity (sarcastity, sarcasticness?)
Just a guess, since you're undervalved , you're hitting the wastegate.
It opens to let off excess boost and suddenly you don't have the air to cool the fire so you get a puff of smoke, then once the excess is bled off, the wastegate closes and puts the fire out till the next time the wastegate opens.
This happens very fast, so it looks like puffs.
phox
Old Sep 6, 2005 | 08:09 PM
plow's Avatar
yea i thought it might but i posted a post earlier today that i have reajusted the afc and starwheel i need to update my sig still getting used to this new look,but anyway i didn't get any replies to that post. after reajusting everything my boost comes on hard and strong at 2200rpm it used to come on at 1600 to 1800rpm, i like the way it pulls now but i developed this intermitent puff of smoke?
Old Sep 6, 2005 | 08:12 PM
plow's Avatar
phox mudler that might explain it because before i reajusted everything i had the wastgate disabled and it wasn,t doing it thanks.
Old Sep 6, 2005 | 11:13 PM
Dr. Evil's Avatar
No sarcasm here - didnt mean it that way !
Im quite suprised there wasnt a puff of smoke before plow adjusted the AFC and starwheel.
Old Sep 7, 2005 | 09:48 AM
Lil Dog's Avatar
The puffs may be dependant on your boost level.. If you are just at the 35 psi mark (or about that) then the gate will pulse open and closed as the drive pressure in the exhaust manifold will also fluctuate which will pulse the gate.
I don't get puffs, but you do see the gate open. There is a good blast of smoke from the start then it greys out to a mist and then starts to darken up as the RPM rises and the boost tops out at 35 psi. Then the smoke starts to get darker until the stock governor backs out the fuel.
Short puffs may indicate a sticky injector. I had that happen on my 89 waaay back. One injector was hanging up and would cause puffs enough to fill a 5 gallon pail intermittantly under full throttle.
92smokin blacky
May 27, 2011 08:49 PM
TXlilbro
Jul 29, 2010 06:37 PM
jlipskoc
Nov 27, 2008 08:41 PM
04ctd
26
Sep 25, 2006 09:47 PM
azjeff
Dec 2, 2003 12:09 PM
