small oil leak ??
Old Feb 19, 2004 | 10:53 PM
dieselcrazy's Avatar
small oil leak ??
hey guys. im starting to get a small spot of oil under my rig when parked. it looks like the oil is coming from the valve covers. i know the 2 rear valve covers were seeping a bit when i bought the truck over a year ago. can the valve covers on these beasts leak enough to cause a few drips on the grond?? what kind of job is it to install new valve cover gaskets ? im heading to fla next week so i will not do it till i get back. i hate to risk the chance of something going wrong before heading out.... thanks guys, scott
Old Feb 20, 2004 | 12:09 AM
dsljunkie's Avatar
It is very possible that the oil is comming from the valve cover gaskets. They are a snap to change. Just pull the long chrome cover off first (the one that says Cummuns on it) it takes a 3/4 in wrench. Then pull each individual valve cover off (15mm). Clean the valve covers off and the sealing surface then reinstall.
Good luck,
Scott
Old Feb 20, 2004 | 06:35 AM
bulthisl's Avatar
If the leak is more to the drivers side it is prob. the blowby tube.
: Eddie :
Old Feb 20, 2004 | 06:37 AM
jaconst's Avatar
don't forget gaskets they are about $30 for all 6 good luck
Old Feb 20, 2004 | 08:55 AM
leak seems to be more on the passenger side. im servicing the rig today ( oil change, grease, etc. ) so ill give a closer look. scott
Old Feb 20, 2004 | 01:58 PM
Sidewinder's Avatar
I thought I had this as well but after I cleaned the engine I think it is actually the injector return line leaking. See the thread INJECTOR RETURN LINE LEAKING in this section. Maybe it's not oil?
Old Feb 20, 2004 | 06:12 PM
LHartman's Avatar
Get the grey gaskets if you replace them, not the black. It's a cinch job. The last cover can be a pain, just take your time.
Loren
Old Feb 25, 2004 | 10:50 PM
ok heres what i saw uner the truck .......laying on my back, feet stickingout beneath the front bumper. if u look up where the power steering resevoir is but behind it towards the cab, u can see a shiny part up there and that seems to be where the dro of oil starts. i hope some1 can picture in their head what im looking at.
Old Feb 25, 2004 | 11:22 PM
infidel's Avatar
Sounds like the vacuum pump seal is leaking, quite common. Dodge will tell you that you have to buy a new pump. Cummins will sell you the seal and o-ring that need replacing.
CruisingRam
Jan 19, 2012 04:45 PM
BAD GRAVY
Mar 9, 2006 09:31 PM
Nappy
Feb 24, 2006 07:57 PM
lowtherc
Oct 11, 2005 03:32 PM
George&cheryl
Aug 6, 2005 11:32 PM
